Does red lining cause damage to the engine?
TOYOTA CELICA
HAZ_65
  • 11 POSTS
Hello, I own a 1995 Toyota Celica 1.8 ST. The mileage is at 76,000. The red line begins at 6,400 rpm and ends at 8,000 rpm. In the morning I was driving to work and i forgot to change the gear to second. The engine was not fully warm. The rev meter reached to 7,500 rpm until i noticed and changed the gear instantly. I would like to know if this may have caused any damage to the engine? If so, what sort of damage? Your help is much appreciated.
Many Thanks,
Oct 27, 2007 at 3:43 AM
Anything internally-you're dogging it-maybe someday it will throw a rod then bingo new engine is needed.
Oct 27, 2007 at 3:47 AM
HAZ_65
  • 11 POSTS
Thanks for the fast response. What is the likeliness I have caused any damage to the engine? If any damage is caused, how will I find out?
Oct 27, 2007 at 3:49 AM
HAZ_65
  • 11 POSTS
How do you mean by the phrase 'dogging it'?
Oct 27, 2007 at 3:50 AM
When it starts making wierd noises. Normally it will come from the lower end of the engine-a lot of pounding is being done down there. Bearings/Caps
Oct 27, 2007 at 3:53 AM
HAZ_65
  • 11 POSTS
So you mean I have damaged the engine quite bad?
Oct 27, 2007 at 3:55 AM
HAZ_65
  • 11 POSTS
Is it guaranteed damage? or if you stray into the red-line, there is a likeliness of damage?
Oct 27, 2007 at 3:58 AM
Dogging it, is where you're straining it,making it do something when it not suppose to.
Oct 27, 2007 at 4:01 AM
HAZ_65
  • 11 POSTS
If damage is caused,k what sort of noise am I expected to hear?
Oct 27, 2007 at 4:05 AM
Piston slapping in the cylinder, Thudding and thumping kind of noise.
Oct 27, 2007 at 4:07 AM
HAZ_65
  • 11 POSTS
From what I explained I did, is it very likely I have damaged the engine?
Oct 27, 2007 at 4:17 AM
You don't hear any wierd noises keep on driving don't worry about it, just take her easy and don't go up that close.
Oct 27, 2007 at 4:22 AM
HAZ_65
  • 11 POSTS
Ye i regret it now. Does the noises appear suddenly or after a while? Ive done it 2-3 times now..I have my music on loud so i cannot hear the engine. I am going to make sure I do not do it again..I get very paranoid :-P Oh yeah..I have another question if you can help? when my car is idol and has warmed up fully and the rev meter goes just below 1 rpm. My car begins to judder and the steering wheel vibrates too. Sometimes its quite bad and sometimes its ok. Would you know what this could be? Many Thanks, Your help is much appreciated.
Oct 27, 2007 at 4:29 AM
You might consider a DIY major tune-up and go find the Idle Air Control Valve remove and clean it- See below
https://www.2carpros.com/forum/automotive_pictures/12900_IACV_1.jpg
www. .com Good Luck my friend don't get paranoia car is just an immaterial things.
Oct 27, 2007 at 4:42 AM
HAZ_65
  • 11 POSTS
Yes thats what many people say to me..I stress too much and its not even worth it. Is it possible you could send that diagram to me by email please? It is [email protected]. Is this valve easy to take off/clean? Ill give it a try later on when I finish work. You seem to know a lot about cars, I am impressed! What car do you drive? You have been a lot of help, Thank you very much!
Oct 27, 2007 at 4:50 AM
Am suppose to know a lot about cars I am a moderator here I have to answer anything that's thrown towards me. I have a 93 MX6 2.5 auto, use it only on special occasion its one of a kind here at home.
Maybe next time you come around donate a lttle and give feedbacks for the help you getting. That's how we make our living helping people in need and also it helps us keep in business. Good luck I'll be sending it.
Oct 27, 2007 at 5:01 AM
HAZ_65
  • 11 POSTS
Ive been trying to give feedback but it dont allow me..it says I done have enough feeback to give? :-S Sorry im new, I am not realy familiar with everything yet. How do I go about giving feedbacks? Thats a nice car by the way..you must be doing a lot to it considering your knowlege! Thanks again for your help!
Oct 27, 2007 at 5:12 AM
https://www.2carpros.com/forum/automotive_pictures/12900_IACV3_1.jpg
Oct 27, 2007 at 5:25 AM
