2003 Celica GTS ABS
2003 TOYOTA CELICA
10 GOALS
  • 4 POSTS
Hi, I have a 2003 Celica GTS with a ABS dashlight that doesn't go off. A shop said it was the right rear ABS senor. Does anyone know how to troubleshoot/repair this problem? Is it easy enough to DIY it? Thanks!
It requires a special tool-look below for a starting point, the right rear sensor will throw a DTC C0210/33 and C1238/38
[img:16f44bc3d7]http://www.2carpros.com/forum/automotive_pictures/12900_2003_Celica_GTS_1.jpg[/img:16f44bc3d7]
Sep 26, 2007 at 1:29 AM
https://www.2carpros.com/forum/automotive_pictures/12900_2003_Celica_GTS_2.jpg
Sep 26, 2007 at 2:43 AM
BUZZSAW
  • 1,198 POSTS
you can also use a muliti meter, unplug sensore and hook up your multi meter in the two wire holes, put setting on ac voltage, spin wheel if a reading occurs the sensor may be good, wiggle the wire too, do this to each sensor
Sep 26, 2007 at 7:47 PM
10 GOALS
  • 4 POSTS
Thanks, will give it a try!
Sep 28, 2007 at 9:49 AM
