2002 Toyota Celica misfire
2002 TOYOTA CELICA
59,600 MILES • 4 CYL • FWD • MANUAL
MARBLE42
after a front end fender bender the engine runs very low
rpms to the point of stalling. Ran diagnostic and the codes say all cylinders are misfiring. Any help would be greatly appreciated .
Apr 21, 2008 at 7:49 PM
SERVICE WRITER
  • 9,123 POSTS
I would start with a thorough look at the area that was impacted by the crash and see if anything looks broken, wires pinched, connector damage or disconnected.
If nothing shows we can component test.
What code number (s) exactly. P0 300?
Apr 21, 2008 at 8:26 PM
SERVICE WRITER
  • 9,123 POSTS
[quote:993758774d="marble42"] made another donation but dont know how to add answer to your question so others can see it.
the codes are
p0300
p0301
p0302
p0303
p0304
p115
p1300
p1305
p1310
p1315.[/quote:993758774d]
Just click the reply to post button at the bottom of the thread to post more.
Apr 22, 2008 at 5:22 PM
SERVICE WRITER
  • 9,123 POSTS
The pcm is up by the battery. The misfire codes are a symptom of the 1300 codes (igniters) The p115 isn't familiar. Based on the impact of the collision and misfores and igniter problems all the way across the board I would stat looking at the pcm. Pull the connectors and get a look for any corossion or damage. PCM may have damage from the impact.
https://www.2carpros.com/forum/automotive_pictures/30961_cel1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/30961_cel2_1.jpg
https://www.2carpros.com/forum/automotive_pictures/30961_cel3_1.jpg
https://www.2carpros.com/forum/automotive_pictures/30961_cel4_1.jpg
https://www.2carpros.com/forum/automotive_pictures/30961_cel5_1.jpg
Apr 22, 2008 at 5:46 PM
SERVICE WRITER
  • 9,123 POSTS
More info as requested.
P0115 has one of three sources:
1-bad ECM
2-bad engine coolant temp sensor
3-short in engine coolant temp circuit.
With that is another nail in the coffin for the ECM, maybe the source of this is in the ECT causing a rich condition and the misfires? May not explain the igniters though.
IF this was p115, then ignore the top.
I'll sending charts for troubleshooting the igniters. In the meantime verify the p115 or p0115
May 7, 2008 at 7:54 AM
KHLOW2008
  • 41,814 POSTS
Hi marble42,
Try checking for a bad ground, would cause the PCM to go haywire.
Jun 7, 2008 at 9:36 AM
