2000 Toyota Celica Injector pulse
2000 TOYOTA CELICA
70,000 MILES • 4 CYL • 2WD • MANUAL
TOM36
Stuck on this car have fuel to the rail plenty of spark and no injector pulse? Checked all fuses and all relays all work just fine if I manually ground each injector. I am stuck and sure its either in the ecm or a broken wire somewhere between the ecm and the injectors any help or suggestions would be great. Thanks
Mar 26, 2009 at 7:57 PM
MMPRINCE4000
  • 8,548 POSTS
I would check the injector harness for missing insulation, the injectors use a common ground, so I would suspect the wiring, before replacing the ECM.
Mar 27, 2009 at 7:49 AM
TOM36
How can I check the ecm toyota dealership is far away and pricey any other way?
Mar 28, 2009 at 12:08 PM
MMPRINCE4000
  • 8,548 POSTS
I would probably try a junkyard for a used ECM. Plug it in and see if injectors work.
If the fuses/fuseable links/relays are all OK, then the injector drivers in the ECM are burned out.
Mar 28, 2009 at 10:04 PM
