2000 Toyota Celica Excessive Rear brake wear
2000 TOYOTA CELICA
13,000 MILES • 4 CYL • FWD • AUTOMATIC
B8BYJENNY
I have a 2000 Toyota Celica GT-S that has been burning through rear brake pads like crazy for the last few years. Typically every three months they start to grind when stopping and require being replaced shortly after. It is my understanding that rear brake pads should not need to be replaced that often in a front wheel drive because the front brakes do the majority of the stopping. What could be causing this excessive wear and how much should I be prepared to spend to have it fixed?
May 28, 2008 at 3:58 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You will need to get the brake bias checked, and the proportioning valve may be faulty. This is a fairly specialist inspection, so you will have to check dealers have the equipment to do the check. I don't have a price on a valve sorry.
Mark (mhpautos)
May 28, 2008 at 6:07 PM
