1998 Toyota Celica knocking
1998 TOYOTA CELICA
12,900 MILES • 4 CYL • 2WD • MANUAL
SOUPDRAGON
I have recently replaced the piston rings and cylinder head on this engine due to the previous owner running it with a very thick oil which blocked up the oil return rings and caused all kinds of problems. For about 300 miles its been running beautifully with good performance and fuel economy. Just recently it has developed a definite knock at switch on which dissapears quite quicklt then anything above 3000 revs on acceleration. I was convinced that when I refitted the conrod bottom end connectors to the crank shaft (with new bearing shells) that I put them back on the right way.....if I have got one the wrong way around......would this be the cause????
thanks for your help....
Oct 11, 2009 at 3:50 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Fitting caps on the incorrect rod or back to front can cause problems like this, normally you would have the problem presenting from first start, i would be checking oil pressure with a mechanical gauge first, then if this is ok, you may have to go back into the sump and re check rod ends and the condition of the bearings.
mark (mhpautos)
Oct 11, 2009 at 4:53 PM
