1995 Toyota Celica weird noise
1995 TOYOTA CELICA
200,000 MILES • 4 CYL • 2WD • MANUAL
ANDRESBUITRAGO1
Hi!!! I just got this car, seems to be pretty good for its mileage, I already changed oil and transmission fluid, and the brakes were just done, but I just find a little weird the fact that the car makes a weird sound as it overpasses 50 mph, it lasts until the speedometer reaches 60 mph, I would like to know what might be the problem so I can go to the mechanic with an idea in mind. Thanks.
Dec 1, 2008 at 1:40 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
where do you feel the noise is coming from, engine, transmission, drive line? let me know and i will think about it.
Mark (mhpautos)
Dec 1, 2008 at 3:06 PM
ANDRESBUITRAGO1
I´m not really sure but it feels like when you´re speeding there is a problem with the axle or some kind of component on the tires, so I would say it comes from the driving line, I appreciate your help, thanks
Dec 1, 2008 at 3:59 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Check the wheel bearings front and rear, there should be no play if you try and move the wheels up and down. check the drive shaft boots are not torn and grease is all over the drive line, have the tyres check for faults if the noise can change with throttle settings (sinning ) you may have a diff problem, have the transmission oil level inspected, start here.
Mark (mhpautos)
Dec 1, 2008 at 8:51 PM
