Engine Performance problem
1992 Toyota Celica 4 cyl Front Wheel Drive Automatic
My check engine light comes on around 55 mph and goes off when I stop, it's throwing a code 25 (lean air/fuel mixture) I just got a full tune up a month ago, I have cleaned the IAC, replaced the TPS, My fuel pump is good. When I accelerate, my car also hesitates, I can push the pedal all the way to the floor, and it takes a second for it to respond, and when it does respond, it still doesn't have the power that it should have. What could be causing this?
Apr 26, 2010 at 1:08 AM
