1992 Toyota Celica CV shaft
1992 TOYOTA CELICA
RBAKER881
Drive Train Axles Bearings problem
1992 Toyota Celica 4 cyl Front Wheel Drive Automatic
Ok , this is an easy one. I have a Toyota Celica that I need to put a CV Shaft back into. I can't seem to get it seated. Is there a trick or do I just need more tenacity?
Aug 29, 2009 at 12:09 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
This should just slide right in and locking place, the only thing that may be stopping you is that the C clip is a bit distorted and this is stopping the shaft from sliding into the splines, the outer spline should also go straight in its just a matter of getting then aligned first.
mark (mhpautos)
Aug 29, 2009 at 12:21 PM
