1992 Toyota Celica brake lines
1992 TOYOTA CELICA
TSHRIVER
Brakes problem
1992 Toyota Celica 4 cyl Automatic 100000 miles
i was wondering if you could give me the average cost of replacing the brake lines in my car?
Nov 19, 2009 at 8:01 AM
MMPRINCE4000
  • 8,548 POSTS
The steel lines are inexpensive, but have to be manually bent to conform to OEM lines. There will be an occasion that you have to cut the line and use a double inverted flare tool to create a new connection.
This is all labor intensive and can get costly.
Best thing to do is go to inlinetube.com and get an entire set of steel lines, cost is usually $200-500. They come in steel of stainless steel, and are pre-bent to fit perfectly.
Dec 1, 2009 at 7:49 AM
