1992 Toyota Celica Acceleration
1992 TOYOTA CELICA
20,000 MILES • 4 CYL • FWD • MANUAL
SIDM4193
Everytime i give my car a little bit of gas "babying it" it goes fine but once i push the throttle in more it will shake the whole car or sometimes even shut off cause the car will shake so bad but sometimes it lets me get on it is it my tps or my oxygen sensor?
Apr 11, 2010 at 10:00 PM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Apr 11, 2010 at 11:18 PM
