1991 Toyota Celica Replacement.....?
1991 TOYOTA CELICA
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
UAWELDER
I was wondering if it is possible to replace the '91 engine and transmission with a 1996 celica 4 cyl./ transmission. If so what other extra parts would I need to do so. Would I need the ECM from the 1996 Celica?
Jan 19, 2010 at 9:16 PM
2CARPRO JACK
  • 11,533 POSTS
The engine may not be a problem if it is the same model/size, just a differenet year. The trans is where the problem may be, if thecomputer engien controls were changed between those yrears.Try calling a local salvage yard adn askthem if they are compatible, they have cross-reference books that tell what will fit in what.The engine if the same size/model, you would be best to just swap the engine (Long block) and use the intake/exhaust/all possible exterior parts off old engine to cut down on possibility of issues. Before installation, it would be agood ideaa to replace timing belt and water pump, alot easier out of the car
Jan 20, 2010 at 7:35 AM
