fresh gas. new plugs. cap and wires good. all fuses good. new air filter. replaced air temp/airflow(MAF?) sensor unit, and ohms out correctly. exhaust needs repair (a bit loud) hole after cat convrtr.
engine won't start(turns over, won't fire) with air filter box cover installed. will start and idle nicely with cover removed and intake 'snorkle' attached, but slow throttle response with intermittant mis firing. engine codes found were 24 (air temp?) and 31 (air flow). these codes prompted the air temp/flow unit replacement. codes have been cleared by battery neg cable removed for 1 minute.
Feb 13, 2009 at 10:32 PM
