I have no brake lights. I have checked all the fuses and all of the bulbs and they are fine. Where do I go from here?
Sep 9, 2008 at 2:10 PM
MERLIN2021
CERTIFIED EXPERT
Check the stop light switch at the brake pedal arm.
DISC & DRUM -1988 Toyota Celica ST
Page 1 of 1
STOPLIGHT SWITCH
Stoplight switch is located above brake pedal. See Fig. 1 . To adjust, remove panel and air duct (if necessary). Loosen lock nuts and turn switch until it touches pedal stop. Tighten lock nut. Check pedal height and brake light operation.
9/9/2008
