1981 Toyota Celica hard start
1981 TOYOTA CELICA
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
UPWITHWINGS
Hello! Thank you for taking my question. My car cranks quite a bit in the mornings when cold before it fires, then seems to run rough for the first few minutes after starting. Until it gets warm, I don't know if it will shut off or not. It can sit for an hour or two and I have the same problem, however, the car seems to run fine once it's warmed up. OCCASIONALLY, it hesitates slightly when I accelerate from a stop (red light or stop sign).
I have replaced the spark plugs and fuel filter. Supposedly a local mechanic has checked the carburetor and found no problems. Accelerator and fuel pump also checked.
My gauges indicate high oil pressure and high battery charging when the car is running at higher speeds.
It's been hard finding someone who can still work on an engine that isn't fuel injected. Thank you for your help!
Aug 24, 2010 at 4:34 PM
DSPLC
  • 220 POSTS
Check your timing on the crankshaft. If it is okay, the only thing I suspect is the carburetor. The automatic choke in the carburetor for cold start is not working properly. Also, from stop and then go acceleration hesitation, on the primary barrel of the carburetor, there is like a needle (like from syringe needle). Once you step on the gas, this needle will squirt gas. Only one squirt of gas everytime you step on the gas pedal. (Not continous). Needle maybe clogged.
Aug 30, 2010 at 3:19 PM
UPWITHWINGS
DSPLC, thanks for the ideas on what to check. Hoping to get the car to a mechanic next week, and I'll pass along your suggestions. Appreciate your input!
Sep 2, 2010 at 8:00 AM
