1987 Camry (4 cylinder, with 3SFE engine) 225,000 miles
I have the above car I am trying to get running so I can give it to a needy person. Here is what is happened so far. No spark. Tested wires, resistance across coil, tested ECU and all seem OK. The repair manual's last step is to replace the igniter. Is there a way to check the igniter before replacing it? I was told to connect a test light to the negative side of the coil and crank the car. The test light should light intermittently. This would indicate the igniter and coil are both OK?
Thanks in advance for any help. I just want to get the car started and give it to somebody who would benefit from having it.
Sep 27, 2007 at 1:54 PM
