replaced 2000 Camry's A140E transmission
2000 TOYOTA CAMRY
SAVEMY2000CAMRY
I replaced my 2000 Camry LE's automatic transmission with another A140E from the junkyard. My car has a 4 cylinder 2.2 liter engine with 190,000 miles on it. At first, the "new" transmission wouldn't begin to engage till the engine was revved up to about 1600 RPM and was completely engaged by 2200 RPM at most. So I figured, maybe some dirt had gotten into the fluid passages and was occluding a valve or something. (The transmission I got from the junk yard had one of its valve bodies scavenged, and dirt had filled that cavity till I cleaned it out easily with a vacuum cleaner.) So, after having driven it only about 20 miles, I replaced the transmission filter and the fluid, which, to my surprise, had already turned brown, and had just a shimmer of tiny metallic speckle, which I took to be aluminum since it was so shiny and didn't accumulate on the magnets.
The new filter didn't seem to help, but after driving a couple more days and a grand total of 80-100 miles with the "new" transmission, the car began to run perfectly -- and I mean as good as gold. And it continued like that for a week, which encompassed 350 miles of operating properly. But now it has become cantankerous again, though not quite in the same way as before. Now, it always starts out fine, but basically every time I come to a stop light, I don't know whether it will engage again right away when the light turns green, or whether it will take a while to get it going. But it's no longer a question of revving the engine to get it to take hold. It's more like either it works just right, or it won't engage at all, and you try it for a while and within a minute it usually gets going again. I should mention that I've been checking the transmission fluid level, and that's been okay.
Once it's engaged, it will operate properly indefinitely. My drive to work includes 20 miles of highway, and it never falters during that whole time, or any other times once it's engaged. There's no fluctuation in power or abnormal engine RPMs. Not till I come to a stop, and more than half the time, it works fine then too. It seems that reverse is more likely to fail than forward gears, and to take much longer to get working again. Low gear, however is no different than drive or second gear, so it doesn't seem dependent on the gear ratio.
So what do you think I should try next? Should I inspect the fluid again, and the pan, and look for clues there? I'm satisfied that the shift cable adjustment is correct. As for the throttle cable adjustment, I have to say I have not tried to fiddle with that, and I don't even know what its function is. It would be great if that were the issue. What affect to the throttle valve have on the operation of the transmission? I've tried to learn that, but haven't gotten a good answer yet.
Well, I appreciate you taking the time to read this. I should mention a couple more facts in case they're helpful. The transmission I got from the junk yard had been removed from a '97 Camry with about 85,000 miles on it. I kept my original torque converter because I had no reason to believe it was faulty. The problem with my original transmission was presumably a "seized clutch", if I'm saying it right. That transmission was permanently wanting to go forward, even when I put it in reverse or neutral (or even park, if I remember correctly). I think it wore out prematurely because I used it to pull a popup camper all over the country.
Can you think of some things I can try in order to diagnose this problem? Maybe I could measure the line pressure during a time that the transmission is failing. I could probably get it to fail in my garage some time. What about some inexpensive fixes to try? What can cause this knd of behavior?
Jun 13, 2007 at 3:46 PM
2CARPRO JACK
  • 11,533 POSTS
If the original trans had broken internal parts, most likely the torque converter was full of debris. By installing it in the new trans, it most likely has contaminated the fluid, possibly causing valves and or solenoids in the valve body to stick intermittently. You could try having the trans flushed, that might help get any debris out of there
Jun 14, 2007 at 8:06 AM
93CAMRY
my 93 camry stalls out after i give it gas but while on idle its ok. could this be fuel injectors or something like that?? change fuel filter
and fuel pump is working.
[quote:602b4a8470="SaveMy2000Camry"]I replaced my 2000 Camry LE's automatic transmission with another A140E from the junkyard. My car has a 4 cylinder 2.2 liter engine with 190,000 miles on it. At first, the "new" transmission wouldn't begin to engage till the engine was revved up to about 1600 RPM and was completely engaged by 2200 RPM at most. So I figured, maybe some dirt had gotten into the fluid passages and was occluding a valve or something. (The transmission I got from the junk yard had one of its valve bodies scavenged, and dirt had filled that cavity till I cleaned it out easily with a vacuum cleaner.) So, after having driven it only about 20 miles, I replaced the transmission filter and the fluid, which, to my surprise, had already turned brown, and had just a shimmer of tiny metallic speckle, which I took to be aluminum since it was so shiny and didn't accumulate on the magnets.
Can you think of some things I can try in order to diagnose this problem? Maybe I could measure the line pressure during a time that the transmission is failing. I could probably get it to fail in my garage some time. What about some inexpensive fixes to try? What can cause this knd of behavior?[/quote:602b4a8470]
Jun 17, 2007 at 6:24 PM
2CARPRO JACK
  • 11,533 POSTS
Check the boot between the air box (Mass Airflow sensor) and the engine for cracks, if the engine moves and opens up a small crack, the mixture gets thrown way off and it can cause the engine to stall
Jun 18, 2007 at 7:17 AM
DMACB333
I have a 2000 Camry same A140E transmission. I too purchased a transmission from a junk yard and another from a private party because the one in the car start leaking profusely. What I did was left the car up on jacks, started it, put it in drive gear, and began pouring trans fluid in it until the transmission engaged. The trans from the private party was first...to this day, it never has engaged. The trans from the junk yard lasted about 2 months before it too started leaking. Taking that one out, I noticed a tiny piece of metal stuck way down in main shaft, I could not get it out. So I pulled the pump and opened it up to see if I could get to that little piece of metal from the other side.
What I found blew my mind. There a cog that free flows inside the pump that was completely destroyed. I'm talking 5 to 8 pieces. I can't tell you the reason this happened but it got me to wondering. I immediately took the other two trans apart. One was good, the other was destroyed.
A good way to check if the pump is working is to check the fluid level with the engine off then again with the engine running. If the fluid level does not change, your pump isn't working.
I took the one good pump, installed it in the original trans, car hasn't skipped a beat since. That was nearly 3,000 miles ago and still running strong.
Note: Never ever install a transmission without replacing the main shaft seal. I had to learn the hard way. Good luck.
Mar 27, 2021 at 10:42 AM
Thank you for that useful information. I'm confident it will help others.
Mar 27, 2021 at 7:02 PM
