fuel pump
TOYOTA CAMRY
PETE56
Where is the fuel pump located on a 1990 toyota camry, engine size is 2000?
The car seems to not be getting gas.
It ran as long as you pump the accelerator.
Feb 3, 2007 at 4:03 PM
JEFTFIELDS
  • 74 POSTS
fuel pump should be in the gas tnk,if your car is fuel inj,if not should be on the front of the block of the moter.
Feb 3, 2007 at 5:22 PM
Lets not blame the fuel pump yet, other things needs to be check prior to condemning the pump.
Get these things check out- the TPS and MAF, and if possible do a fuel pressure check with a gauge not the eyeball or thumb method. Once the above checks out we'll go somewhere else.
Feb 4, 2007 at 3:55 AM
