Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Cheers,
Image (Click to enlarge)
Aug 27, 2006 at 4:47 PM
BRENT32
MEMBER
Thank you! I love this site.
Nov 20, 2018 at 10:44 AM
DENNIS FOX
MEMBER
1 POST
Where is fuel filter located?
(Merged)
CERTIFIED EXPERT
The fuel filter is mounted on the driver side of the engine compartment, below the charcoal canister
(Merged)
DEEANN919
MEMBER
Engine Performance problem
1993 Toyota Camry 4 cyl Two Wheel Drive Automatic
How do I locate and change a fuel filter on this vehicle
(Merged)
CERTIFIED EXPERT
The fuel filter located under the air intake tube that carries the air to the throttle. Remove that black tube, only 3 screws/nuts and then u see the black filter there. Remove the nut that lies on top of the filter, then the one at the bottom. The bottom one is a bit hard to get to. Then remove the clamp that secures the filter to the car, again only 2 nuts/screws. Replace and reverse directions.
(Merged)
MECONTR
MEMBER
1 POST
1992 Toyota Camry 4 cyl Front Wheel Drive Automatic 152k miles
where is the fuel filter located on a 1992 toyota camry?
(Merged)
CERTIFIED EXPERT
Follow the aircleaner duct before it gets to the throtttle body its right below the duct at driver side-
