door latch
TOYOTA CAMRY
JEFF ATKERSON
1995 camry 127000mi 4cylinder toyota.My driver door will not open. All the electric locks work,the linkage seems to be fine. I have narrowed the problem down to the latch that connects to the door post. Problem is I cant get the door open to remove the door panel. The only solution I can come up with is cutting out the door panel so I can get to the latch. Any advise would be appriciated.
Nov 29, 2007 at 8:30 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
First try removing the passenger side trim so you know how it all works. you should be able to make a rod to reach down from the top, use the other side as a template. Remove the belt trim, (Rubber strip that seals window and door) so you can get a little better access. Try this before wrecking the trim.
Mark (mhpautos)
Nov 29, 2007 at 6:16 PM
