CLIMATE CONTROL PANEL REPLACEMENT
TOYOTA CAMRY
LARRYO
I am asking about a 2000 Camry, with 63000 miles on it. The 'Automatic' climate control panel in my 2000 Camry is erratic. Can I replace it with a manual one? If so, what's the best way to remove the plastic trim around the panel?
Thanks for any help.
Mar 30, 2006 at 3:47 PM
LOSONE
  • 1,616 POSTS
Almost impossible to replace an auto with a manual. The bezel has plastic clips. use a small hook tool to free it. There might be a screw or two under the lip.
Check your temp sensors before you replace the auto module. If there have been smokers in the car they have a tendencey to clog from nicotine. They also clog with normal dust. Check them 1st. Good Luck.
Mar 30, 2006 at 5:32 PM
LARRYO
2000 Camry - 63000 miles.
Thanks to losone for the quick reply. Can you tell me where the A/C Temp Sensors are located?
Mar 31, 2006 at 1:22 PM
LOSONE
  • 1,616 POSTS
They are behind a small grill about the size of a 25c piece on the dash. Somestimes they one by the windshield
Mar 31, 2006 at 2:08 PM
