i was driving at 40 mph when i hit a medium sized bump. i then heard a strange noise(like something dropping). within a few seconds i had no gears working including reverse and car coasted to stop, engine still running fine. when i try shifting from any gear to park i hear a scary metalic grinding noise. no leaks under car. I can still push car when it is in park. 10 days earlier i rear ended another car and sustained front end damage(crumpled hood, smashed headlights. i had front end pulled out without damaging radiator or condensor and the car was running fairly well for 9 days. Any ideas on what the problem is likely to be. I am hoping it is not the transmission since repairing would cost more than car's worth. 92 toyota camry le-4 cylinder-2 wheel drive-92000 miles- automatic transmission thanks in advance, HK2000
Aug 11, 2007 at 11:20 AM
