90 Camry Driveability issues
1990 TOYOTA CAMRY
TEMPLER1
Hi, I have a 90 camry 4cyl. 235,000 miles and I'm having a driveability issue. Sometimes while driving down the road my car will cut out on me, sometimes it will start back up and I can take off again, and sometimes it will keep dying over and over. I noticed it usually happen when I'm at a full stop then start to accelerate. It seems to happen alot when its cold and raining also. I've already put many new parts on it like a throttle position sensor, a cold start valve, an air flow meter, I've had the wires and spark plugs replaced. It seemed to run fine after replacing those parts but after awhile it would start cutting out on me again. I just don't know what to do anymore I've run out of ideas. Can anyone please help, Thank You.
Dec 1, 2006 at 12:57 PM
WHEATSIX
I don't know if this will help, but I had some similar problems with my 90 Camry. My car only had the issue when it had rained outside or if the humidity was really high that day. All I had to do to fix the problem was to replace a piece of rubber hose in the fuel system. I believe it was a fuel return line hose. Hope that helps. :D
Dec 5, 2006 at 8:01 PM
[quote:9d8dd6fac0="Templer1"]Hi, I have a 90 camry 4cyl. 235,000 miles and I'm having a driveability issue. Sometimes while driving down the road my car will cut out on me, sometimes it will start back up and I can take off again, and sometimes it will keep dying over and over. I noticed it usually happen when I'm at a full stop then start to accelerate. It seems to happen alot when its cold and raining also. I've already put many new parts on it like a throttle position sensor, a cold start valve, an air flow meter, I've had the wires and spark plugs replaced. It seemed to run fine after replacing those parts but after awhile it would start cutting out on me again. I just don't know what to do anymore I've run out of ideas. Can anyone please help, Thank You.[/quote:9d8dd6fac0]
Check the EGR and fuel filter to include the fuel pressure to rule out the pump and regulator
Dec 9, 2006 at 9:12 PM
