2010 Toyota Camry 2010 Toyota Camry SE
2010 TOYOTA CAMRY
JOHNADMIN
2010 Toyota Camry 4 cyl
I just bought a brand new 2010 Toyota Camry SE about 2 weeks ago. It has only 700 miles on it but has begun leaking oil from underneath the car!
I took it to the dealership and they said it was a 'rear main leak.' They said they will need to take the engine and transmission out to repair my car.
It will take many days to get the part in to the shop, then many more days to do the repair. But it will be at no cost to me, other than having no car for a while.
I use to believe that buying new cars would mean I would not have car problems.
Is it a common occurrence for a new car to leak oil?
Should I demand a new car?
Is this 'rear main leak' going to have an effect on the life of the car and is there a better chance problems will spring up later at higher mileage? (When the warranty is out...)
Nov 29, 2009 at 6:22 AM
BMRFIXIT
  • 19,053 POSTS
no way they need to give you at least a car to drive while the repair is being done
and I think if you make enough noise you can demand another vehicle
call Toyota
Nov 29, 2009 at 7:00 AM
Its giving you problems at 700 miles -leaking rear crank seal -for me the engine hasn't been broken-in properly and not even due for an oil change and this is happening. I wonder what lies ahead. Get rid of it, don't make a deal for nothing on this car-GET RID OF IT!!!!!!..........
Nov 29, 2009 at 7:05 AM
JOHNADMIN
I spoke with the general manager explaining the situation here is his reply:
I wanted to send you a quick email letting you know that the vehicle is ready. After a very thorough inspection and test drives, the techs discovered that the vehicle did not in fact have any oil leaks. It was simply some of the grease used when they assemble the various engine parts that had become hot and slowly moved to the bottom of the motor. The service advisor or manager can give you a thorough recap if you would like more information. Please let me know if I can do anything else for you. Thanks.
Do you think this is legitimate?
Thanks for your help.
Dec 14, 2009 at 11:53 AM
