Cabin filters
2007 TOYOTA CAMRY
32,000 MILES • 4 CYL • 2WD • AUTOMATIC
ED.B
How do I replace the acc cabin filters in my Camry? Where are is it located? Will I need any tools? Thank You, Ed from Pittsfield, MA
Sep 25, 2009 at 12:08 PM
DOCFIXIT
  • 18,828 POSTS
Hi Remove glove box
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_147.jpg
Push inward on sides of box let it hang down Remove filter caes
https://www.2carpros.com/forum/automotive_pictures/198357_Grafic_3_42.jpg
Remove filter from case
https://www.2carpros.com/forum/automotive_pictures/198357_Grafic_4_14.jpg
When installing new use "up" mark
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_5_8.jpg
Sep 25, 2009 at 12:32 PM
YUKAMHON
When I use the defrost, my interior windshield fog up. I suspect it may be caused by the dirty cabin air filter. I had not changed it for four years, and 50,000 miles. I was told it is located near the compartment area. I follow the instruction from the box of the new filter, and could not drop the compartment box down as instructed. I am not doing it correctly. Please advise. Also, what tools do I need to get to the cabin air filter. I can use a better diagram if it is available. Thanks.
Stephen
Mar 10, 2021 at 6:14 PM (Merged)
If you can follow all the instruction/illustratiion you're home sweet home-Good Luck
https://www.2carpros.com/forum/automotive_pictures/12900_2004_camry_cabin_air_filter0_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_2004_camry_air_filter1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_2004_camry_cabin_filter2_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_2004_camry_air_cabin_filter3_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_2004_camry_cabin_air_filter4_1.jpg
www. .com Have a nice day/make sure you tell your friends about us.
JRB0001
where is it,& how do I replace it?
AIR CONDITIONING FILTER REPLACEMENT
https://www.2carpros.com/forum/automotive_pictures/12900_af_2.gif
1.Open the glove box. Remove the screw with a Phillips-head screwdriver and slide the hook as shown. 2.Push each side of the glove box to disconnect the claws. 3.Remove the filter case from the filter outlet as shown. 4.Remove the filter from the filter case. 5.Inspect the filter on the surface. If it is dirty, it should be replaced. Installation Reverse removal procedure.
JJRB
Where is it located & how do I change it?
BLUELIGHTNIN6
  • 16,542 POSTS
it's behind the glove compartment. open the glove box, remove the screws and slide the hook. disconnect box claws by pushing inwards on sides of glove box and allow box door to hang down. remove filter case from the outlet. remove filter from the case and replace filter.
SINBADTIBURON
How I replace a cabin air filter in Toyota Camry?
Mar 10, 2021 at 6:15 PM (Merged)
MHPAUTOS
  • 31,937 POSTS
Hi there,
Here is a guide to help you see what you are in for when doing the job with diagrams below to show you what it will be like for your car:
https://www.2carpros.com/articles/how-to-change-an-air-cabin-filter
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Cheers
RUBONE625
Where is my cabin air filter located?
ZACKMAN
  • 4,202 POSTS
https://www.2carpros.com/forum/automotive_pictures/55316_97camrycabinfilter_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_97camrycabinfilter2_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_97camrycabinfilter3_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_97camrycabinfilter4_1.jpg
CNA20086
where is the cabin filter located in my toyota camry 1998
Mar 10, 2021 at 6:16 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
The cabin filter is in the A/C evaporator housing which is located behind the center of the instrument panel. Below you will find some illustrations and a guide to help you find and change the filters
