VSC, TRAC and Engine light is on when driving. OBDC shows P0031. Replace air fuel sensor with oem part 89467-06050 (after confirm that original part on veh is also 89467-06050/Denzo). Clear error codes with OBDC. VSC, TRAC, Eng lights came back on after short drive. After 2 days, tried reset by holding odometer button and turn on ignition and also clear error P0031, dash lights turned off successfully for about 20 minutes driving, but unfortunately turned on again. 5 days later, still hv same dash lights on and OBDC shows three monitor test not complete with icons flashing and gives error code P0031 twice. (only single P0031 before relacement air-fuel sensor). Replace the other air-fuel sensor located at bottom?? Thanks for help.
Jul 17, 2009 at 11:29 AM
