2005 Toyota Camry brake lights
2005 TOYOTA CAMRY
98,000 MILES • 4 CYL • FWD • AUTOMATIC
ADAM32
ok i have a problem with my brake lights they wont go off if i pull the fuse they go out also while the fuse is pulled it wont go into gear and while the fuse is in the cruise control wont go on because oof the brake lights stayin on
Aug 10, 2008 at 2:15 PM
MERLIN2021
  • 17,250 POSTS
On the brake pedal arm find the stop light switch, it either out of adjustment or no good, push the switch into the brackett, then pull up on the brake pedal.
Aug 10, 2008 at 3:10 PM
