2004 Toyota Solara 57,600 miles v6 automatic
2004 TOYOTA CAMRY
Hi, I brought my car to a new toyota dealership today (we moved so its new to us) for 60k service, I did so early because the winter weather is coming up and they'll be swamped, also, a few weeks ago I began hearing a rumbling sound underneath the car loud when I excellerate. Its annoying but doesn't seem to effect performance. I assumed that it was the muffler although when I had the brakes done they said everything else looked good (3 months ago) The service tech at Toyota told me that everything is fine, the noise is coming from the catylitc convertor but its nothing to worry about. My bill was $438, No brake work needed they were newly installed, they didn't rotate the tires because my best are in the front and I've been told I need new ones before winter (by them). I left there feeling bad, I don't like the sound coming from my car, if its the CC its still under warranty, I think they should fix it so it doesn't make the noise, am I being unreasonable in your opinion?
Thanks so much (inadvance for your help)
Teri
Sep 17, 2007 at 8:14 PM
FISHERMAN
  • 937 POSTS
[quote:84b1ef1ce6="[email protected]"]Hi, I brought my car to a new toyota dealership today (we moved so its new to us) for 60k service, I did so early because the winter weather is coming up and they'll be swamped, also, a few weeks ago I began hearing a rumbling sound underneath the car loud when I excellerate. Its annoying but doesn't seem to effect performance. I assumed that it was the muffler although when I had the brakes done they said everything else looked good (3 months ago) The service tech at Toyota told me that everything is fine, the noise is coming from the catylitc convertor but its nothing to worry about. My bill was $438, No brake work needed they were newly installed, they didn't rotate the tires because my best are in the front and I've been told I need new ones before winter (by them). I left there feeling bad, I don't like the sound coming from my car, if its the CC its still under warranty, I think they should fix it so it doesn't make the noise, am I being unreasonable in your opinion?
Teri[/quote:84b1ef1ce6]
A new car its not suppose to have any issue!
you are right if the C.C. its making noise its because its not working propperly (something its loose inside) like a broken cell...
Anyway they charged to much money for the "service"
did you check the list of parts they replaced?
let us know!
hope it helps!
Sep 18, 2007 at 2:37 PM
BUZZSAW
  • 1,198 POSTS
[quote:f3cd8d837f="fisherman"][quote:f3cd8d837f="[email protected]"]Hi, I brought my car to a new toyota dealership today (we moved so its new to us) for 60k service, I did so early because the winter weather is coming up and they'll be swamped, also, a few weeks ago I began hearing a rumbling sound underneath the car loud when I excellerate. Its annoying but doesn't seem to effect performance. I assumed that it was the muffler although when I had the brakes done they said everything else looked good (3 months ago) The service tech at Toyota told me that everything is fine, the noise is coming from the catylitc convertor but its nothing to worry about. My bill was $438, No brake work needed they were newly installed, they didn't rotate the tires because my best are in the front and I've been told I need new ones before winter (by them). I left there feeling bad, I don't like the sound coming from my car, if its the CC its still under warranty, I think they should fix it so it doesn't make the noise, am I being unreasonable in your opinion?
Teri[/quote:f3cd8d837f]
let us know!
hope it helps![/quote:f3cd8d837f]
toyota warrenty is 5/50000 I belive, unless its a cirtified car through toyo, or you have extended warr
Sep 21, 2007 at 11:26 PM
