2004 Toyota Camry rubbing, creaking, noise
2004 TOYOTA CAMRY
2,400 MILES • 6 CYL • 4WD • AUTOMATIC
LEGALESE
hello, suspension or brake problem?
i hear a rubbing, creaking noise from the rear of the vehicle while driving. noise is worse on bumpy areas and not noticeable at all on smooth roads. I thought i had something in the trunk that was hitting against the side of the vehicle. i shifted items in trunk first. Then cleaned the trunk out. Noise is still happening. Has been about a week now that i have been hearing the noise. checked the owner's manual. had no luck. Your thoughts? thanks for the help.
Feb 19, 2010 at 8:33 PM
TWINSRAM
  • 42 POSTS
It sounds like a suspention issue. Maybe you don't need new struts. They can just be greased with high temp multi-purpose grease. If the struts are good, this will fix the problem
Feb 25, 2010 at 1:16 PM
