2004 Toyota Camry A/T refill
2004 TOYOTA CAMRY
90,000 MILES • 4 CYL • FWD • AUTOMATIC
CHURCHEL
In the process of changing the oil in my A/T i also dropped the pan and changed the filter. After putting everything back together I proceeded to re fill the transmission. The owner's manual says the capacity on a drain and refill is 3.7 quarts. I have 4 quarts in now and the oil level is not quite up to the cold level. How much oil above the the 3.7 quarts thats recommended should I expect to to need ? I don't want to overfill the tranny.
Jan 2, 2010 at 10:13 AM
MERLIN2021
  • 17,250 POSTS
If you put in 4 quart, run the car to normal operating temp, park it on level ground, check level in park, fluid expands a bit when hot...
Jan 2, 2010 at 10:25 AM
