2003 Toyota Camry Head Light
2003 TOYOTA CAMRY
126,423 MILES • 4 CYL • 2WD • AUTOMATIC
JOHNSONHO
  • 8 POSTS
My high beam will not turn on. The high beam indicator turns on. But the high beam lights never turn on. I have checked the fuses. When I switch to high beam I can hear a relay click in the fuse box under the hood. I also do no believe the day time running lights is not working either.
Jan 2, 2010 at 9:31 AM
KHLOW2008
  • 41,814 POSTS
Hi johnsonho Thank you for the donation. From the symptoms, the DRL 4 Relay is most likely to be faulty.
https://www.2carpros.com/forum/automotive_pictures/192750_Relayblock03CamryFig07_1.jpg
Try swapping the relay with the MG Clutch relay to see if it works.
Jan 2, 2010 at 10:19 AM
