2003 Toyota Camry Gear noise, vibration in steering wheel a
2003 TOYOTA CAMRY
190,000 MILES • 4 CYL • FWD • AUTOMATIC
JEF9876
My high mileage Camry 2.4 (AT) is making what sounds like gear noise which increases with speed. It is car speed releated, it still occurs if I put the car in N and coast. If I rev engine at slow speeds it does not change.
It is felt the the steering wheel. I have rotated tire with no change. I have checked the brakes- nothing found. With both front wheels off the ground and trans in N, rotating the wheels I can not feel anything strange.
Any ideas of where I should look next?
Jan 24, 2010 at 7:57 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Seems to be a wheel bearing drive car when noise is heard turn steering wheel slightly to left then right any change in noise?
Let me know
Thnaks for donate
Jan 25, 2010 at 9:00 AM
JEF9876
thanks for the reply, no steering does not affect it at all. Axle bearing is what I was hoping for. It reminds me of a diff failure on an old RWD car I once had.
Jan 25, 2010 at 8:14 PM
DOCFIXIT
  • 18,828 POSTS
If no change in pitch then wheel bearings may not be problem. Most likely a Diff bearing. Jack front wheels off ground place on jack stands. Run car in gear noise present? hear it from Diff? place long screwdriver on Diff next to ear will pick up noises
Jan 27, 2010 at 9:11 AM
