front passenger seat will not go back after it was moved all the way to the front?
2003 TOYOTA CAMRY
SAMMY77
I don't understand why the front passenger seat will not go back after it was moved all the way to the front. The motor clicks when you press the button and it heats up but the seat will not push back. There is nothing hindering the track and I cannot see if it has locked or anything. Any ideas on how to fix it?
Sep 28, 2007 at 1:11 PM
FISHERMAN
  • 937 POSTS
If the front passenger seat in your 2003 Toyota Camry won't go back after it was moved all the way to the front and you've verified that there's nothing hindering the track, there may be an issue with the seat's motor or mechanical components. Here are some steps you can take to troubleshoot and potentially fix the problem:
Check for Obstructions: Double-check the area under the seat and the seat track to ensure there are no foreign objects or debris that might be preventing the seat from moving.
Reset the Seat Motor: Sometimes, the seat motor can get stuck or encounter an electrical glitch. Try disconnecting the car battery for a few minutes and then reconnecting it. This might reset the seat motor and potentially resolve the issue.
Inspect the Seat Motor and Wiring: Carefully inspect the seat motor and its wiring for any signs of damage or loose connections. Check the connectors and wiring going to the seat motor to ensure they are secure and in good condition.
Test the Seat Switch: If possible, test the seat switch to ensure it's functioning correctly. Use a multimeter to check for continuity when pressing the seat adjustment buttons.
Manually Move the Seat: If you can access the seat tracks, try manually moving the seat back and forth to see if it's just stuck in a certain position. Be cautious when doing this, as the seat can be heavy and may require some effort to move.
Inspect Seat Tracks and Bolts: Examine the seat tracks and mounting bolts for any signs of damage, rust, or misalignment. If the tracks are damaged or misaligned, it can prevent smooth movement of the seat.
Sep 28, 2007 at 1:36 PM
SAMMY77
I tried to push it and see if there was some kind of lock but nothing. The motor is clicking like it wants to move but the shaft is not moving. The motor is also heating up because of the numerous times I am trying to make it move. What's next?
The next step its to pull out the motor and test it out...
(with the same connector.)
in some cases its easiest to unbolt the seat, that way you have more space to work with.
Sep 28, 2007 at 4:28 PM
