replacement procedure for the driver side mirror
2003 TOYOTA CAMRY
RWE817
What is the replacement procedure for the driver side mirror. It is motorized but not heated.
Feb 13, 2009 at 3:31 PM
SQM
  • 6,383 POSTS
The outside mirror replacement procedure is very simple.
First you will have to remove the triangular shape plastic cover that is located inside the door at the back of the mirror mounting point. Removing that cover will give you access to the mounting bolt.
Simply unplug the wire and take off the nuts.
Here is a helpful video:
https://youtu.be/nkfWvMJAXGI
Thank you.
Oct 13, 2021 at 12:54 PM
