[quote:9112668578="merlin2021"]First remove the tire, then the caliper, then the rotor, then use the hammer and drive the old lug out, insert new ugs and install a nut BACKWARDS with a large washer, and tighten to pull it into the hub, when it's seated against the hub, you are done...[/quote:9112668578]
Thanks Merlin2021 for the detailed procedure.
Feb 17, 2009 at 12:17 PM
