2002 Toyota Camry Problems
2002 TOYOTA CAMRY
MARCHMADNESS
2002 Toyota Camry 51500 kilometers. When i take a turn or stop and turn the wheel my car makes a very loud cracking sound and continues while i accelerate, nothing happens while i drive straight. The loud cracking comes from the front left tire and i am not sure what it is and I would appreciate any advice you could give.
Mar 26, 2006 at 9:01 PM
LOSONE
  • 1,616 POSTS
I am losone the new Toyota moderator.
The loud cracking sound as you describe is more than likely a CV joint failure. It is not safe to drive the car so have a mechanic check the LF out side CV.
In all probability the boot cracked letting all the grease out and ruining the joint. I know when my joints run out of lube, I crack all over! Good Luck
Mar 29, 2006 at 2:03 PM
