2002 Toyota Camry My oil smells like gas!!!!!
2002 TOYOTA CAMRY
16,000 MILES • 4 CYL • FWD • AUTOMATIC
JULIE5719
I have a 2002 Camry with 160,000 miles. The check engine light has been coming on and going off since about 80,000 miles. The dealership would turn off the light and check and could never find anything wrong. Now the light stays on all the time and my oil smells like gas. I have had the fuel injectors serviced, but this did not appear to help. The smell is not as bad but it still smells like gas. The car smokes (white smoke) when I crank it in the morning and in the afternoon leaving work. The dealership says that it is the catalytic converter. Is this a possibility? I'm not sure how much money I want to sink into a car with this mileage, but I would like some suggestions as to what may cause this. Please help! Thanks!
Aug 6, 2009 at 10:23 AM
STEVEW84
  • 673 POSTS
First, what are the codes for(need number and description). Second, when the last time you changed the oil and had a tune-up done? Third, has anything been done the car recently?
Aug 7, 2009 at 7:00 AM
JULIE5719
First, thanks for the reply! I looked on the dealership invoice and the code they have listed is P0420. I usually have the oil changed every 2 or 3 months (depending on mileage). The last tune up was at approx. 120,000 miles. I plan to change the spark plugs and have the transmission serviced at the next oil change or when the cat. converter is replaced (if that is the problem). I pretty much do what is recommended. Could the PCV vlave also contribute to the check engine light? Is that something that should also be checked? No one has said anything about the PCV valve. Also, do other things contribute to the cat. converter issues? Any input would be greatly appreciated!
Aug 10, 2009 at 8:22 PM
STEVEW84
  • 673 POSTS
Well, the cat. converter is most likely bad. There are a few things to look at to condemn it(fuel trims, monitors,etc.) but you would need a scanner to do that. I would probably be doing a tune-up soon. PCV valve is good to replace when your doing a tune-up. Probably not why your CEL is on. If you replace the cat. converter you need to get it from the dealer if you want the light to stay off. HTH.
Aug 10, 2009 at 10:41 PM
