2002 Toyota Camry Car hesitates only on deacceration orer 4
2002 TOYOTA CAMRY
49,000 MILES • 6 CYL • FWD • AUTOMATIC
WALTER COMB
The car runs well in acceleration doen't have problem around town drivinbg but when going over 45 and let up on accelerator the car hesitates or bucks - may do it several times in succession. Set on gas and accelerates smoothly. Car was taken to dealer 18months ago and spent $400 to have "1000 check system recalibrate trans ecu - set fliud levels to proper level. Problem was still there and we gave up but know want to fix problem so need help
Jun 18, 2009 at 3:44 PM
MERLIN2021
  • 17,250 POSTS
Check the air filter, if clean, replace the maf or the iac(idle air control, Did you install any aftermarket electronics? if yes EMI can be the problem too. Electromagntic interference.
Jun 20, 2009 at 7:15 PM
WALTER COMB
Air filter is new. Which do I change MAF or IAC and why will they create my problem. Another "help sight" says it probably a sticking EGR valve. I'm looking to get some concensus bufer spending fortune. Please talk it around - I need help or wife will want new car
Jun 22, 2009 at 11:03 AM
MERLIN2021
  • 17,250 POSTS
A bad IAC will cause rough idle and deccelleration troubles, and the MAF controls injector pulse width, a stuck EGR will be problematic at all sppeds even at idle, the futher open it's stuck, the greater the problem, until it won't start , or stay running. Can be that but not as likley, no codes? If you have a smooth idle, the MAF is probably the weak link... At 35-45 your engine works the hardest as it goes into 1 to 1 ratio with the tranny.
Jun 22, 2009 at 12:58 PM
MERLIN2021
  • 17,250 POSTS
You did say the ECM was reflashed with the new software, and this label was applied under the hood on the driver's side? Toyota suggests test the fuel control circuit for "surging" problems.  On Avalon, Camry 2.2L 4-cylinder gasoline models, Camry 3.0L V6, Camry Solara, Celica, Corolla, ECHO, Highlander, MR2, Prius, RAV4, Sienna, Tacoma, Tundra 3.4L V6 and 4Runner, check fuel pump control circuit. See FUEL PUMP CONTROL CIRCUIT under COMPUTERIZED ENGINE CONTROLS in appropriate SYSTEM & COMPONENT TESTING article.
https://www.2carpros.com/forum/automotive_pictures/62217_camry_2.jpg
EGR Position Sensor (Camry & Camry Solara) 1. Disconnect electrical connector at EGR position sensor. EGR position sensor is located on top of EGR valve. See Fig. 172 . 2. Using ohmmeter, check resistance between terminals E2 and VC on EGR position sensor. See Fig. 172 . Resistance should be 1500-4300 ohms. If resistance is within specification, reinstall electrical connector on EGR position sensor and go to next step. If resistance is not within specification, replace EGR position sensor. See EGR POSITION SENSOR under ENGINE SENSORS & SWITCHES in REMOVAL, OVERHAUL & INSTALLATION - V6 & V8 article. 3. To test EGR position sensor output voltage, disconnect vacuum hose from EGR valve. Remove glove box for access to Engine Control Module (ECM). Turn ignition on. Using voltmeter, check voltage between ECM terminals E2 (Brown wire) and VC (Yellow wire). See Fig. 173 and Fig. 174 . Voltage should be 4.5-5.5 volts. Remove voltmeter. 4. Connect voltmeter between ECM terminals E2 (Brown wire) and EGLS (White/Green wire). See Fig. 175 and Fig. 176 . Using vacuum pump, apply 5.1 in. Hg of vacuum to EGR valve and note voltage. Voltage should be 3.2-5.1 volts with vacuum applied on EGR valve. Release vacuum from EGR valve and note voltage. Voltage should be .4-1.6 volts with vacuum released from EGR valve. Replace EGR position sensor if voltage is not within specification. See EGR POSITION SENSOR under ENGINE SENSORS & SWITCHES in REMOVAL, OVERHAUL & INSTALLATION - V6 & V8 article. Remove vacuum pump and reinstall vacuum hose on EGR valve. NOTE: EGR position sensor may also be referred to as EGR valve position sensor.
https://www.2carpros.com/forum/automotive_pictures/62217_camrya_1.jpg
Also you can pull of the vacuum hose and use a vacuum pum with engine running, if it starts to stall or run rough with vacuum applied, release the vacuum, if it smoothes out, the EGR isnt sticking...this has an electronic position sensor mounted on top of it, if it's open at the wrong time, a code will set and turn on the check engine light. IAC TESTING: Camry Solara, Tacoma & Tundra 3.4L V6 1. Start engine. Warm engine to normal operating temperature. Ensure idle speed is within specification. See IDLE SPEED & MIXTURE in ON-VEHICLE ADJUSTMENTS - V6 & V8 article. 2. Turn ignition off. Apply parking brake and place transmission/transaxle in Neutral. Ensure A/C is off. 3. On Camry Solara, install Jumper Wire (SST 09843-18020 or SST 09843-18040) between terminals TC and E1 on data link connector No. 1 located at passenger's side of engine compartment, near strut tower. See Fig. 137 . Go to step 5 . 4. On Tacoma and Tundra, note location of data link connector No. 3 at driver's side of instrument panel. See Fig. 30 and Fig. 31 . Install Jumper Wire (SST 09843-18020 or SST 09843-18040) between terminals No. 4 (CG) and 13 (TC) on data link connector No. 3. See Fig. 139 . Go to next step. 5. On all models, start engine and note engine speed. On Camry Solara and Tacoma, engine speed should increase to 1000 RPM for 5 seconds and then return to idle speed. On Tundra, engine speed should increase to 900-1500 RPM for 5 seconds and then return to idle speed. On all models, if engine speed is not as specified, test IAC valve resistance and IAC valve operation. Go to next step. If engine speed is as specified, remove jumper wire. Turn ignition off. 6. To test IAC valve resistance, ensure ignition is off. Disconnect electrical connector at IAC valve. IAC valve is located on lower area of throttle body. Using ohmmeter, checking resistance between +B terminal and each remaining terminal on IAC valve. See Fig. 141 -Fig. 142 . 7. Replace IAC valve if resistance is not within specification. See IAC VALVE RESISTANCE table.
Jun 22, 2009 at 1:13 PM
