First of all, the radiator fan should turn on when the engine reaches its operating temperature. It also turns on when the A/C is on.
An inoperative radiator fan can be due to a bad relay, faulty wiring, defective coolant temperature sensor or a bad fan motor.
First check the relay. This vehicle has 3 relays for the cooling fan. They are located in the under-hood fuse box.
I have attached diagrams on how to test the relays as well as the temperature sensor and the fan replacement procedure below for your reference.
Thank you.
Jan 29, 2022 at 8:30 PM
