2001 Toyota Camry oil pan gasket
2001 TOYOTA CAMRY
147,000 MILES • 4 CYL • FWD • AUTOMATIC
ROBOT46
how do i get the oil pan off do i have to pry it off
Mar 24, 2010 at 5:28 PM
DAVE H
  • 13,384 POSTS
Tap it a few times or pry it off without damaging it !
OIL PAN
Removal
Disconnect negative battery cable. Raise and support vehicle. Remove lower engine covers. Drain engine oil. Remove front exhaust pipe located below oil pan.
Remove stiffener plate at rear of oil pan (if equipped) for access to oil pan. Remove dipstick. Remove bolts/nuts and oil pan.
Installation
Ensure sealing surfaces are clean. Apply bead of sealant at center of oil pan sealing surface, between bolt/nut holes and on inside of bolt/nut holes.
Install oil pan. Tighten bolts/nuts to specification. See TORQUE SPECIFICATIONS . To install remaining components, reverse removal procedure. Fill crankcase with oil.
Mar 24, 2010 at 8:36 PM
