2001 Toyota Camry Gas Tank
2001 TOYOTA CAMRY
95,450 MILES • 6 CYL • 2WD • AUTOMATIC
CALGUT
When I try to put gas in my car, gas flows for 2 gallons, but then it's stop and go because fuel rises causing the fuel hose to stop. However, if I shoot the fuel into the gas tank, it does not stop...any idea why the fuel would not flow when the hose in entered as normal. What I mean by shot is I hold the front section of the hose back with my hand and press the handle to dispense fuel.
Jun 1, 2010 at 6:22 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
The fuel tank breather is not working, this is the EVAP system, it can be a bit complex and it may require the removal of the fuel tank, i would get a mechanic to pin point the part of the system that has failed, this will require first hand inspection.
mark (mhpautos)
Jun 1, 2010 at 9:03 PM
