The right front caliper piston does not disengage.
It burned a set of pads very quickly. I replaced the pads, I turned the rotor, installed a remanf. caliper to no avail. replaced the rubber brake line, problem remains. after a test drive I raised the right front and find the wheel is impossible to rotate by hand and has a strong burning odor. where do I go from here?
Dec 30, 2007 at 2:32 PM
