2001 Toyota Camry Air conditioner fan or fan switch
2001 TOYOTA CAMRY
111,000 MILES • 6 CYL • FWD • AUTOMATIC
JOETOMEI
My air conditioner fan runs only in the highest speed setting of the speed selector switch.
Would the problem most likely be in the switch, the fuses, or the moror?
Aug 4, 2008 at 3:07 PM
MERLIN2021
  • 17,250 POSTS
MANUAL A/C-HEATER SYSTEMS -2001 Toyota Camry LE Page 1 of 1 BLOWER RESISTOR Unplug resistor connector. Using DVOM, check for resistance between resistor terminals No. 1 (Blue/Orange wire), No. 2 (Black/White wire), No. 3 (White/Black wire) and No. 6 (Blue/Black wire). See BLOWER RESISTOR SPECIFICATIONS table. See Fig. 4 . If resistance is not as specified, replace resistor and retest system. BLOWER RESISTOR SPECIFICATIONS Terminals No. 2 & 4 .38 ohms,2 & 3 1.12 ohms,1 & 3 1.74 ohms Fig. 4: Identifying Blower Resistor Connector Terminals Courtesy of TOYOTA MOTOR SALES, U.S.A., INC. Ohms .38 1.12 1.74 8/4/2008
https://www.2carpros.com/forum/automotive_pictures/62217_Graphic_12.jpg
Aug 4, 2008 at 3:23 PM
ONE4UF
Joe,
I have a 2000 Camry and began having the same problem earlier today. I smelled an electrical type burn like something shorted out and then realized the fan works only on the lowest and highest setting. I've had problems in the past with the dash lights behind half of the a/c control panel not working before so I thought maybe that entire switch panel was bad. What did your issue end up being and about how much was it to fix?
Thanks!!
Jun 28, 2009 at 6:44 PM
JOETOMEI
I gave up repairing the circuit myself. I figured out that the resistor needed to be replaced, but it seemed a bug job to find it and replace it. I had it fixed by the Toyota dealer. It cost $161.74
Jun 28, 2009 at 7:06 PM
ONE4UF
Excellent. Thank you.
Jun 28, 2009 at 9:17 PM
MERLIN2021
  • 17,250 POSTS
Sometimes you eat the bear, and sometimes the bear eats you...Engineers that design them should be forced to fix at least one of em!
Jun 29, 2009 at 4:11 PM
