Electrical problem
2000 Toyota Camry 4 cyl Front Wheel Drive Automatic
If you start car by jumping starter, it blows the 10amp gauge fuse after a few minutes of run time. I have replaced the PCM, the neutral safety switch, and pulled the relay to the fuel pump. It still blows the 4amp starter fuse when ignition is in start position after all of that.The engine was recently rebuilt and all connectors are in their receptacles, and all grounds are hooked up. I idled the car for 5 hours with no problem, and drove it for 30 miles before this happened after the motor was rebuilt. The only problem that i was concerned with before this happened was that the temperature would have to get in the red before the cooling fans would come on. and the ac didnt work even though it did before the rebuild.
May 8, 2010 at 6:28 PM
