2000 Toyota Camry Dome Light on Vienta
2000 TOYOTA CAMRY
104,000 MILES • 6 CYL • 2WD • AUTOMATIC
IANHOEY
Dome light works in ON position. Just recently it has ceased working when on DOOR position, even when all doors are open. Switches appear free. Dome switch movement appears normal.
Dec 18, 2009 at 6:11 AM
MHPAUTOS
  • 31,937 POSTS
HI there, you will need to check that power is passing through the toggle switch in the dome light on the door position, i have seen many that are just a poor connection, it's just a rubbish switch that they use, sometimes a bit of emery over the contacts work.
mark (mhpautos)
Dec 18, 2009 at 8:01 AM
IANHOEY
Thanks Mark. All is now OK.
Dec 18, 2009 at 6:46 PM
GREENVOMIT8
Cleaning the contacts on the dome switch was fidly but it worked for me. Thanks Mark.
May 27, 2012 at 3:23 AM
