2000 Toyota Camry Check engine code P0449
2000 TOYOTA CAMRY
129,000 MILES • 4 CYL • 2WD • AUTOMATIC
DOLEMITE44149
  • 17 POSTS
Hello everyone! The check engine light has come on in my car and the diagnostic code I get is P0449. "P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction"
Looking for advice. I was thinking to try and start simple and just replace the gas cap but wanted to check the forum first.
Thank you in advance for your help!
Greg
Jul 9, 2009 at 8:31 PM
KHLOW2008
  • 41,814 POSTS
Hi Greg,
Thank you for the donation.
You are correct about the code and description but for Camry, this code does not apply. Can you please reconfirm it?
For the gas cap, it usually would show as P0442.
For Camry EVAP system codes are P0440, P0441, P0442, P0446, P0450 and P0451.
Jul 11, 2009 at 10:13 AM
DOLEMITE44149
  • 17 POSTS
Sorry, I had the code re-read. It is actually P0446
Thanks again
Greg
Jul 12, 2009 at 12:28 PM
KHLOW2008
  • 41,814 POSTS
Here is a description of the possible causes and it is not caused by the gas cap. Most likely problem would be the VSV valve located are rear near to fuel tank. however it could be any of the valve suystems and the diagnostics are rather extensive. Would you like to do the diagnostics your self?
https://www.2carpros.com/forum/automotive_pictures/192750_VSV00Camry_1.jpg
DTC P0446: EVAP VENT CONTROL CIRCUIT.
https://www.2carpros.com/forum/automotive_pictures/192750_P0446_00Camty_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_EVAPComp00Camry_1.jpg
Jul 12, 2009 at 3:52 PM
DOLEMITE44149
  • 17 POSTS
Yes, I would like to run the diagnostics myself if possible.
Jul 12, 2009 at 9:32 PM
KHLOW2008
  • 41,814 POSTS
Here are the diagnostic procedures.
https://www.2carpros.com/forum/automotive_pictures/192750_P0446_00Camry01a_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_P0446_00Camry01b_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_P0446_00Camry01c_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_P0446_00Camry01d_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_P0446_00Camry01e_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_P0446_00CamryFig01_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_P0446_00CamryFig07_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_P0446_00CamryFig08_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_P0446_00CamryFig09_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_P0446_00CamryFig10_1.jpg
Jul 13, 2009 at 10:47 AM
DOLEMITE44149
  • 17 POSTS
Perfect! It worked! Thank you for your advice.
Greg
Sep 4, 2009 at 3:14 PM
KHLOW2008
  • 41,814 POSTS
You are welcomed and glad to be of help.
Thank you for using 2carpros.
Sep 5, 2009 at 12:37 PM
