Dome Light
2000 TOYOTA CAMRY
FATBOYPIZZAEATER
I have a 2000 v6 LE camry with 65K milegage on it. My car's dome light is not glowing and I checked the bulb and it is good. I was trying to check the fuse (one under the change holder and one under the hood) and could not find any fuse labeled by "dome". How could I find and replace it. All other interiors (Radio, dashboard) are working fine.
Thanks and I appreciate your time.
May 21, 2007 at 12:06 PM
That fuse is in the under hood fuse box,fuse #14 = 7.5AMP here is a guide to help you test the fuse.
Here are the fuse panel locations and identification (below) you should keep this page in your favorites for future reference. It shows the relays as well
Feb 13, 2018 at 12:30 PM
MICHAEL SAPP
Thank you!
