Transmission problem
1999 Toyota Camry V6 Two Wheel Drive Automatic 103000 miles
Hi....
I had changed my gasket and gasket pan couple of weeks ago by using the AT filter Kit because I noticed some leak and the gasket was really worn out. The change was done in a garage and they added more oil to make up the leak.
Tonight when I was on the road the transmission failed. I noticed it was taking more time to shift the gears and I had to pull out the car to a park lot. In the park lot, the transmission died and I was only able to engage the R mode but the others L,2,D did not work.
I hope you can bring me some light of what happened.
Hi....
Dec 2, 2007 at 1:03 AM
