1999 Toyota Camry strut noise
1999 TOYOTA CAMRY
GRANTO500
Suspension problem
1999 Toyota Camry 6 cyl Front Wheel Drive Automatic 104k miles
there is a sloopy noise coming from the right front strut... esp when going slow and going over uneven terian or potholes... at high speed there seems to be no noise.. at least I can not hear it... I had the local mechanic look at it... he does not know... I called toyota on the phone and one said it may be the strut holder on top.... what do you think it is..
Feb 11, 2008 at 9:36 PM
FISHERMAN
  • 937 POSTS
[quote:bc9df48b38="granto500"]Suspension problem
there is a sloopy noise coming from the right front strut... esp when going slow and going over uneven terian or potholes... at high speed there seems to be no noise.. at least I can not hear it... I had the local mechanic look at it... he does not know... I called toyota on the phone and one said it may be the strut holder on top.... what do you think it is..[/quote:bc9df48b38]
Could be a loose strut or the rubber "cushion" its not tight agains the frame.
raise your vehicle and be sure that everything its secure and tight.
also could be a damage strut (internal).
good luck!
Feb 11, 2008 at 9:55 PM
