1999 Toyota Camry sluggish and makes popping sound on accel
1999 TOYOTA CAMRY
194,000 MILES • 4 CYL • 2WD • AUTOMATIC
PUNTER27
Just the other day out of the blue about halfway thgru my drive home the car suddenly had difficulty in accelerating. In stop and go traffic, when stepping on gas the engine would seem to choke, then an air popping sound would be heard in engine compartment (sounded like it was on drivers side near firewall) but woud eventually get back to normal. Problem is really noticable when going 'uphill' from a stop or uphill when needing to accleerate even more .... slugish as if it wanted to stall, then choking type air popping sound, then off it would go.
Have left car in driveway until this weekend to look at, could this be a vacum hose type of issue? Any input woudl be helpful
Jun 9, 2010 at 1:39 PM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Jun 9, 2010 at 1:43 PM
